Author information - your oral presentation or poster
Author Registration
If your full paper has been accepted into the ACDC Global 2027 programme, you are required to register for the conference. When registering, please ensure you enter your paper number.
Accepted as an oral presentation?
Register for the conference by Monday, 21 December 2026; otherwise, your paper will have to be withdrawn from the conference
Submit your PowerPoint presentation on the submission system by Monday, 15 February 2027
Oral presentation submit here
Check the programme regularly, as it may change
PowerPoint presentation instructions
Each presentation is allocated 10 minutes. A joint Q&A for all presenters will follow at the end of the session, once all presentations are complete
Upload your PowerPoint file by Monday, 15 February 2027
The slides will be loaded onto the session laptop by the organisers prior to the relevant session
Authors/speakers should bring a copy of their slides on a USB with them to the conference as a backup
PowerPoint presentation guidelines
Use a 16:9 aspect ratio
File must be in .ppt or .pptx format
File size must be no larger than 500MB
Choose colours that keep text and diagrams easy to read when projected
Use short bullet points rather than paragraphs or large blocks of text
Present information as clearly as possible, using tables, graphs or diagrams where helpful
Keep your slides brief – your time goes very quickly
Accepted for a poster presentation?
What you need to do…
Create a poster for display in the digital poster gallery and for physical display at the conference. You can find the template available to download below
Submit a one-slide poster pitch presentation that sums up your poster. You have two minutes to present this in an oral session in the programme. You can find the PowerPoint template available to download below
Poster presentation submit here
Print and bring your poster with you on the day. We will supply materials to attach your poster to the poster board but cannot print your posters for you
Poster instructions
During the breaks, it is encouraged that you be at your poster to network with other delegates
The poster board size is portrait A0
A digital version of your poster will also be viewable to attendees in our digital poster gallery
You should clearly display the following information on your poster:
The title of your paper
The authors’ names and their affiliations
Your usual contact details (e.g. an email address) to allow delegates to follow up with you
Useful tips
Your display should consist chiefly of keywords, diagrams, photographs, etc
Diagrams and graphs should have clear captions
All text should be easy to read
Use colour to emphasise important features
All graphs and diagrams should be drawn with thick lines (preferably 1mm or more in width)
Handwritten text or diagrams are not recommended
Remember…
The display should be visually appealing and should contain the essence of your paper in a form that is easy to understand
Try to attract the registrants to your poster. Unless they come to it, you cannot expect to have a discussion with them
The poster can contain visuals that were not present in your paper
The poster display is important. It is recommended that you put as much time and effort into its preparation as you did into your written paper
Personal data
Personal data will be processed by the Institution and its associated organisations for the purpose of organising your attendance at this event. It may also be used for the promotion of other IET products and services and contacting you for market research purposes.
By providing us with your postal address, email address and telephone number you agree that we may contact you by these methods.
You can change this preference at any time by either contacting us by post, following the link on a received email or amending your preferences if you have a MyIET online account.
To view the IET data privacy statement and for details on how we handle your data, please visit IET Events Privacy Policy.
Journal publication opportunity
Authors of selected papers from ACDC Global 2027 will be invited to submit an extended version of their paper for consideration to two IET journals: High Voltage and IET Generation Transmission and Distribution. We will be publishing a Special Issue featuring papers from the conference.
