Sponsor profiles
Find out more about our 2027 sponsors.
HVDC World
HVDC World is a specialized research and intelligence platform focused on HVDC projects, providing detailed technical, commercial, and investment data. Our platform gives a complete holistic view of what's happened, what's happening, and what will happen in the world of HVDC, giving you the data you need to make well-informed decisions.
Megger
Megger supports the testing, monitoring and fault location of critical transmission infrastructure across subsea, underground and overhead applications.
From offshore wind export cables and HVDC interconnectors to new overhead transmission corridors, our solutions help operators improve asset visibility, reduce downtime and respond with confidence when faults occur.
Transmission assets often carry large volumes of renewable power between generation sites, substations, countries and grid regions.
When they fail, operators need to act quickly. The right testing, monitoring and fault-location strategy helps teams move from uncertainty to action with clearer information and faster decision-making.
As renewable generation grows, transmission networks are carrying power across longer distances and more complex routes.
A single fault can affect availability, revenue, repair planning and grid stability. For subsea and underground links, access can be difficult. For overhead lines, visibility across long-distance infrastructure is essential.
Megger supports transmission teams before, during and after faults occur. We help utilities, TSOs, renewable developers, EPCs and specialist contractors test, monitor and locate faults on the assets that keep renewable power moving.
Mitsubishi Electric
Mitsubishi Electric is a global leader in manufacturing and sales of electrical and electronic products and systems used in a broad range of fields and applications including communications, consumer electronics, industrial technology, energy and transportation.
Mitsubishi Electric is a world class manufacturer of electrical substation equipment and a trusted partner of utility companies in the global and European energy market.
With a focus on innovation we are well placed to support our customers in a fast changing modern energy market with stricter regulation, greater consideration of environmental issues and increasing demands for energy.
RXHK
Rongxin Huiko Electric Co Ltd is a global leader in the manufacturing of high-power power electronics equipment. RXHK is engaged in R&D, design, manufacturing, factory testing and commissioning of primarily PP-IGBT technology based equipment.
The main products include VSC-HVDC, STATCOMs, Battery Energy Storage Systems and high-power variable frequency drives. RXHK solutions provides power quality improvement, control optimisation, energy saving and losses reduction to our customers.
RXHK has nine VSC-HVDC contract references, including one for a 800kV 5GW valve, the world’s largest. More than 90 sets of high power MV Drives have been supplied, with a total capacity >1.8GVA. RXHK’s STATCOM solutions are present on five continents and include multiple units of 200MVar or greater.
RXHK's corporate headquarters is in Anshan in Liaoning Province, China. RXHK's UK subsidiary Rongxin Power Ltd is based in Altrincham.
